Total NOOB question!
Since I found TFP before I found a pool builder, I quickly learned not to discuss the pool chemistry method I would be using. Blank stares and then the "here is what you should do..." You can stick with the basic in line chlorinator (the pucks), use it during their startup, and then just leave empty once you take over the reigns. I asked my PB if he could make the pipe that would hold the in-line chlorinator at least 2 ft long in case I decided to install a SWCG in the future. No problem!
I ended up getting the SWCG before he even did the plumbing.
