TFP uses a different methodology from traditional pool care. TA is one of the big differences.
Traditional pool care numbers are based on using acidic trichlor pucks to chlorinate the pool. You have to have a higher TA then, to counteract the acid those pucks are constantly adding.
SWCG / liquid chlorine are fairly pH neutral, but with the natural off-gassing of a pool, it will trend upward in pH instead of down. With the higher TA and no acid from pucks to counteract it, your pH would be constantly rising and you'd be adding acid manually (through muriatic acid) to counteract that rise. That would lower your TA, and you'd be adding more "alkalinity up" (which is also known as baking soda if you want to save a ton of money on chemicals) to raise your TA, and repeat forever.
That's why TFP has a lower TA recommendation.
Do you have a kit to do the testing yourself? We've found that pool stores are...spotty at best with their tests. You never know how well their people are trained, how well their equipment is calibrated, etc. Your own dropper-style test from a Taylor K2006c or TF-100 is a better bet to ensure your levels are what they really are.
