- Aug 8, 2021
- 51
- Plaster
- Pentair Intellichlor IC-40
My pool service company added too much salt to my pool. It is reading 4000ppm. I believe the max is 3400ppm. The chlorinator will not work due to high salt amps. The now fired pool service company said I do not need to drain the pool. It will leave on it's own. (see her comment below). I believe that is very incorrect. can someone confirm?
You do not need to drain the pool water due to high salt level - that is only needed for high conditioner or CYA. The salt level will resolve naturally without you doing anything. All you need to do is keep testing the levels in case it needs more near the end of summer.
