I have been having difficulty maintaining a proper chlorine level in my pool this whole summer (has actually been an ongoing issue since 2017 but much worse this year even though I purchased a new pump and filter system last summer, and this pool has been partially drained twice since 2017 because of high CYA levels and is why I rarely use pucks). I did go to the pool store about 2 months ago and they told me that I had nitrates in my pool and it would have to be drained, rinsed and drained again. Suspicious, I ignored that but kept shocking the pool with just Cal-Hypo every week to sometimes every few days (approx. 16oz each time) but never could maintain a FC above 0.5, didn't use tabs since my CYA was in the 80 range. I went through an entire 25lbs of Cal-Hypo in a little over a month. Bought another and was told my CYA was down to 60 so added a puck to the feeder to try and keep some chlorine in the pool between shocks.
I just got back from being away for about 4 weeks and while the pool was maintained by a friend by shocking it weekly with Cal-Hypo (approx. 20 oz) per week and keeping a couple tri-chlor tabs in the feeder set low, and brushing, I now have what looks like mustard algae on sides and steps that can't be brushed away. So yesterday during the day I added about 24 oz of Cal-Hypo since the pool was at about 0.5 FC and a pH of 8.0. I knew it would take a lot of chlorine to kill whatever can't be brushed away. Then last night I added 10 oz of muriatic acid and waited an hour to then added 4 gal of 10% liquid chlorine. I did not do a DPD test as I determined I was going to need a lot more liquid chlorine than that 4 gal, but thought the chlorine level would still be high by the next morning.
This morning the FC is down to 2.5 according to the DPD and the Taylor K-1004 test showed 1.0. Seems like an awfully drastic drop in Cl overnight. So I'm wondering if I should just drain the 13,000 gal pool since it only costs like $150 to fill it and I'm spending way more than that chasing a Cl level. I did pick up 6 more gal of 10% Liq Cl for use tonight but don't want to use it if I'm just going to end up draining the pool.
As of 1040 this morning my levels are:
2.5 FC (DPD test), 1.0 (K-1004 test)
0.5 CC (DPD test), 0.5 (K-1004 test)
1.5 TC (K-1004 test)
7.5 pH (so the 10 oz of muriatic did work)
45 CYA
120 Alk
86 degrees F
I don't have a calcium hardness test but like to keep it high since this is a plaster pool.
45 CYA
120 Alk
86 degrees F
