I switched to controlmatic SWCG ever since I got the hot tub new and I’ve been burning thru heater elements every 6-7 months. First 3-4 were replaced under warranty but now that the warranty has expired it’s getting costly to replace. The last heater element only lasted 4 months.
I’ve even lowered the salt to around 1500ppm.
The only thing I don’t do is use it often enough that the pH tends to drift high for extended periods.
I did have CYA around 30ppm for the first year but stopped adding that.
I drain and refill twice a year.
Am surprised not seeing more people running into this issue…
