I think that it's probably low flow. I would start with a clean filter and properly configured valves. I know that I keep bringing it up, but I don't think that the valves are set correctly. What speed is the pump set to?
Did you fix or replace the hot tub handle and turn it the correct direction. Just from the pic you can see it is not only broke, but turned the wrong way. Sure your past that by now...
