Hey everyone I was just wondering what your preference is about putting chlorine pucks in the skimmer vs a floater? I have a solar cover and I’m going to be gone for 4 days and want to prepare for it
Yea I just assumed if it is in the skimmer it would destroy that pump I only use liquid chlorine. Unless absolutely needed to use tabsNever deposit chlorine tabs in the skimmer, when using a floater insure that it’s not allowed to sit stationary directly over a seat or steps.
I just had my pool refinished, and the company they had manage the water for 2 weeks after plaster did exactly this. I actually removed them and placed in a floater because it seemed wrong to me. This company also tried to sell me on a $160/mo winter water management program.Never deposit chlorine tabs in the skimmer, when using a floater insure that it’s not allowed to sit stationary directly over a seat or steps.
The product is not 'disbursed' by the container floating around. The water disburses it just fine.then floaters do not work well and chlorine will be poorly disbursed.
I feel with the auto cover or solar cover, the floater will be easier to keep at the deep end of the pool since the water won't be affected by the wind?I think it depends on your system. If you have an automatic cover or a solar cover, then floaters do not work well and chlorine will be poorly disbursed. If they are in the skimmer, the pump should be running 24/7 and ideally you have a variable pump and can run
If I close my autocover on a floater, it drags the floater to the shallow end. I wedge the floater in the corner of the pool where the spa dam is, which happens to keep it near a return and away from skimmers, before closing the cover.I feel with the auto cover or solar cover, the floater will be easier to keep at the deep end of the pool since the water won't be affected by the wind?
From my experience putting pucks in a floater will not distribute enough chlorine especially for a pool your size. I tried this for 7 days and the 2 pucks I put in the floater were still around 80% of their original size.Hey everyone I was just wondering what your preference is about putting chlorine pucks in the skimmer vs a floater? I have a solar cover and I’m going to be gone for 4 days and want to prepare for it
