I think I'm finally ready to make the switch to a SWG this year.
I have a 18' round Summer Wave Above Ground pool (about 7,600 gallons) with an Intex Sand Filter.
This is the SWG I'm thinking of getting: Amazon.com : Intex Krystal Clear Saltwater System with E.C.O. (Electrocatalytic Oxidation) for up to 15000-Gallon Above Ground Pools, 110-120V with GFCI : Gateway
So I have a few questions and just want to verify I have the procedure set correctly
I'll be opening my pool on Friday. I'm sure it will be green and nasty. I will shock it with liquid bleach and get my FC levels up and my PH balanced. I use a Taylor K-2006 to test my levels.
So after my pool is nice and clear and levels are good I will hook up the SWG. I know I will need to test the amount of salt I have in my pool at this point. Can I use my K-2006 for that? I know I will have SOME salt in my pool because of the bleach. I've been reading that I will need to get that level up to about 3200 ppm. Which would mean about 300lbs of salt (if I'm at 0). So once I pour salt in my pool, I just need to turn on the SWG and set it to maintain at 3200 and I'm all set?
Also, someone a few years ago told me that a SWG in Michigan is pointless because the weather is not consistency warm enough in the summer and it causes issues with a SWG... is this true? Does the water temperature effect it? It's true in Michigan the weather can get chilly even in the summer and water temperature can fluctuate pretty frequently.
I just want to make sure I understand this before I buy and commit to the SWG.
