33K gallon SWG pool. Considering adding borates as an extra algae buffer. I test my water about weekly, but sometimes life happens and we forget, lose power, etc and the dreaded bloom occurs. Seems to happen once or twice annually (very early spring is always prime time, or inevitably we leave town, lose power and my variable speed pump shuts off and goes into error mode and doesn't turn itself back on). So with that in mind I'm thinking about adding borates to act as a buffer. I'll need to add around $200 worth of boric acid to get it up to 50ppm.
So...is the juice worth the squeeze? I have never had an issue with high ph and rarely have to add acid to reduce, so that benefit is off the table for me. But does it really reduce chlorine demand by 30+%? I keep my CYA at around 80 (super hot southern summers) so I have to maintain 6+ ppm FC. Based on what i've read I can go down to 5% of CYA or 4ppm FC which technically should extend the life of my SWG.
