Our pool guy quit when I was unable to return to the house, he had not been going to the pool as often as he should and it got away from him so he quit, leaving the pump off for 4 weeks. The pool is full of green slime and so dark you cannot see the bottom. I am in the process of emptying the pool to jet wash and acid wash to try to get the plaster clean as it is stained in places. Its a SWG pool with cartridge filters and I am concerned about locations I cannot get to once I put in new water that may start the algae bloom all over again. I am in the Bahamas so cannot get now filters easily will I be ok to use the filters and have been filtering out lots of algae prior to water replacement.
1. Any suggestions as to what I may be able to treat the filters with to eradicate the algae that may be lurking in the filter.
2. Will a cartridge filter survive jet washing.
3. Should I slam the pool once the water is replaced and it is up and running.
Thanks Lindy
Thanks Lindy
