The irrigation hose delivered more than the other 3 combined. I started the first two at 3 p.m. and the irrigation line at 8 p.m. I got up at 3 a.m. and shut the irrigation line off (afraid it would over fill) by 8 a.m. the pool was full. YMMV
Genius! - You just told me how to fill my pool when it is ready!! I have a 1" irrigation line (on city water) I had to cut and cap where the pool will be built. I'm going to make a 1" fill line from that!
I do have an irrigation line 15 feet from the pool. I cut and capped it off for the excavation. My thoughts were to put a hose bib end on it to use it to fill. It gets way higher flow than my outdoor spigots.
OK - I just told a friend about this - he JUST had his pool refinished. He said: "New finish on pool will not tolerate high volume and 'they' had to slowly fill his pool to not damage the new finish. How would you diffuse the high pressure so you don't damage the finish?
But put the splitter on the spigot. If you want to use head loss equations, you must measure the pressure at the hose attachment point WHILE the flow rate is going through the hose. The static pressure is irrelevant.
What you are measuring is the head loss through the hose. A shorter hose will have less head loss (for a given flow rate) or lower pressure loss. So if you plug these numbers into the web site (assuming they are doing the calculation correctly), you should get a higher flow rate out of the shorter hose with the lower pressure.
As a rough approximation, head loss in a pipe can be expressed as the following:
Head loss (ft) = Constant * Pipe Length / Diameter^5 * GPM^2
So even if you measure lower pressure (i.e. head loss), it can and is offset more by the length of the pipe so GPM is higher.
I just realized that site doesn't allow for variable pressure. But you can use this formula for a rough approximation
[CORRECTION]
Pressure loss (PSI) =3.32e-4 * Pipe Length / Diameter^5 * GPM^2
So for a 18 PSI pressure loss in a 75' hose, GPM is 13 GPM +-
Or I could just get a flow meter.
