You can get a Spot style robot or an Atlas Style robot or you can custom design a robot for your specific needs.
That's actually an interesting idea. The telemetry could go back out through the power cable. The robot would supply the power to the array. No batteries, no Wifi. Me likey.I urge you to imagine a waterproof sensor attached to the robot or vacuum head that cleans your pool. James has a sophisticated (and expensive) robot that has that built in but you can put your own hand built waterproof sensor attached to the robot or vacuum head and get the exact same functionality.
Scary stuff. These guys surely have watched all the Terminator movies, which begs the question: what are they really up to?You can get a Spot style robot or an Atlas Style robot or you can custom design a robot for your specific needs.
Also, my thread explains how I'm using my pool temp sensor for analytical and predictive stuff too, not just determining if I want to go swimming on any given day.Why not just plumb the probe in your plumbing.
Sidebar. The correct answer to any trivia question about Gilligan's Island is always: Mary Ann.
Roger that!The only way to get accurate 24/7 temp sensing in the plumbing is to run the pump 24/7.
Pfffffffffft. That's shorts and flip flops weather. I saw 22 a couple times last night.if your pool is 54 degrees and the outside is 57 degrees you are living much too cold.
