- May 23, 2015
- 24,702
- Plaster
- Pentair Intellichlor IC-60
I'm wondering if By accidentally bring the FC to 22 might have killed things that weren't affected at the 20 and below FC Mark. Would that explain the drop in FC overnight and increase in cc?
No, that's not happening. Your FC/CYA ratio at 20ppm is well above the kill threshold for algae. In order of easiest to kill to hardest to kill it goes like this (simplistically) - viruses, bacteria, protozoan oocysts & bacterial spores and, finally, algae. That's simplistic as there are probably some oocysts that are harder to kill than some spores and algae can be broken up into different types but it's roughly the way it goes.
So at 20ppm you are killing algae and everything else. As you increase your FC you'll oxidize more organics and your FC loss rate will increase a little, but it would seem you still have a ways to go.
You can always bring your pool water up to mustard algae shock levels as that is the hardest type of algae to kill. But TH definitely can not swim when you do that and I would only do it when you can spend time working on the pool (weekends?).
