Thanks for the 'toast'. Believe Me...I was literally toasting my husband with a cold one when the CYA finally came down and we were able to move forward. I am committed, and will continue to post progress!
kwhyde said:Frogabog....thanks for advice....you posted at 1:30 am, so I was in bed. We have full sun today till 9 at night. Should I put bleach in now or wait till tonight? Also, I just use pool calc to determine how much, correct? Current FC 0, target 9, so 280 oz. of bleach. Did I do that right?
frogabog said:Right now, I'd say you're in fairly good shape and may not need to shock. But only if you get the chlorine in right away. Tonight, raise the water to 9ppm FC with bleach. Check half an hour later to see if you hit 9ppm. An hour after that, see if you lost chlorine. (I am assuming you are doing this at night). If not, let it be overnight. Check for CC as well.
<edited>
If doing this during the day, some chlorine will be lost due to sunlight so just watch it till the sun is off the pool and make sure it doesn't fall below 4ppm before the sun is off the pool (if it does, time to shock). If you lose 50% of the chlorine you started with, you're good. Re-dose to 8ppm for the night and let it go the next day.
