First time pool owner. Had some great help here, on my electronics last summer, first months with new house. Well California has gotten beat with rain/hailstorms, and i didnt think my test strips were giving me accurate ideas of pool chemistry.
So, I Got my TF-Pro kit. I like the magnetic mixer!
PH: image attached. no idea if its 8.2 or off the scale
Cl Br: image attached. chlorine bromine?
FC: 17.5 (35 drops)
CC: zero (no color change with 5 drops)
ALK: 250 (25 drops x 10)
CYA images attached. First image was standard 7.5ml pool water, and then fill to the 15 (+7.5ml). Second image (closer to 100mark ) was a diluted 50/50 pool/tap water mixture. Its maybe half way to the 100, then multiply by 2? To me, that reads as probably a CYA of around 400?
So, help me understand PH, to me it looks about 8.2? CYA thru the roof, but its hard for me to keep track of CYA and FC ratio and what you can still live with, as long as its balanced. Alot of info on this forum, and its made my head hurt.
I use tablets. algae seems to popup every day. pool isnt cloudy specifically, but definitely need to brush everyday.
From what ive gathered, i need to likely drain and refill to get rid of all the CYA that's built up from tablets not doing their job the right way?
I have at times shocked, and added some pure baking soda in the past, based off my test strip readings at the time. But i have not done anything in weeks, and now have a real test kit. So, its a new fresh start i suppose.
FC: 17.5 (35 drops)
