- Jan 22, 2022
- 213
- Plaster
- Pentair Intellichlor IC-40
Our spa is 7x7 attached to our pool and has an opening to let water overflow into the pool (pic attached). Our PB set up pool mode to where the actuator doesn’t fully shut off to the spa on the return side (I think?) so there is a small waterfall effect from the spa when in pool mode. I run the pumps 8 hours a day so that small waterfall is happening for that same 8 hours. The true spillway mode is not set up (nor do I know if it even can be?) My question is about water chemistry. Is that small spillover from pool mode enough to circulate water into the spa so that whatever chemicals I’m adding to the pool with eventually feed into the spa and sanitize it the same way or does the spa need it’s own chemicals added in it and it’s own water test separate of the pool? Thanks!
