jcowart
0
Start out by bringing it upto about 30 to 40 and use the manual dose chart until you get the SWG dialed in. Then you can slowly bring the CYA up and dial back the SWG. I don't have a SWG but I run my CYA at about 50 and a higher target. I live in Southeast Texas and my pool sees sun from rise to set. The numbers are different because a manual dose is like a spike and slow fall. A SWG is a steady supply of chlorine.
Edit: That's why it is recommended to turn off the SWG while fixing problem. With it off you will see that the FC daily use is. A SWG is good at maintain a balanced pool but can't really fix problems with out manual help.
