I’m trying to test my FC level with the kit and when I add in r-0870 it turns the water pink like it should. So I move on to adding the 0871 and after about 5 drops the water turns clear so I assume I’m at a FC of 1 (using 25ml sample). But after a couple seconds the water will turn pink again. Is this normal and I should keep counting or is the test going wrong?
