Are you beginning a SLAM? If so, get us all on the same page with results from your new kit!
FC - xx
CC - xx
pH - xx
TA - xx
CYA - xx
FC - xx
CC - xx
pH - xx
TA - xx
CYA - xx
FC - xx
CC - xx
pH - xx
TA - xx
CYA - xx
No one said to start one.Are you beginning a SLAM? If so, get us all on the same page with results from your new kit!
FC - xx
CC - xx
pH - xx
TA - xx
CYA - xx
I thought i replied to you sorry for delay. The water looks amazing FC and CYA and PH are in check now. I dont have exact numbers at work, notebook at home. going to watch all the videos again to see where I go from hereI hear you......what does your water look like?
cc is somewhere between .5 and 1 I need to address this but it could be error in my test water levelSo,
1. your water is crystal clear with NO SIGN of algae
2. CC's test result is .5 ppm or less
3. You pass the OCLT
Then you are good to go for the rest of the season. Brush often....keep FC right about where you have it and enjoy your swim season!
That's easy enough to repeat but don't waste any time after the FC test is complete to keep moving with the CC test until done.cc is somewhere between .5 and 1 I need to address this but it could be error in my test water level
