Good for you Cathy. I knew it would be easier once you drained. You still may have some shocking left but you just about have this sorted out.
Brushpup said:Good for you Cathy. I knew it would be easier once you drained. You still may have some shocking left but you just about have this sorted out.
techguy said:Each day you learn a little more about how to care for your "pool pet". I was hoping I was feeding you the information you needed right then.
This is taking far too long. Don't wait until tonight to repeat the process - check it again in two hours and top off the bleach. Don't let up - algae is a formidable foe. Once it's knocked down, kick it! Again and again and again until it's dead.Catherineb said:Ha I'm awake, I'm awake.....I forgot to tell you I do not rise early from my bed
Yes the sun has come and taken some chlorine.
FC 5.5 that's a bit of a drop from 12
CC 7
Just added more bleach and will repeat process tonight and keep you posted.
Thanks
Cathy
jblizzle said:For CCs, you likely do not even have to wait more than an hour before you retest.
techguy said:Your CC is coming down and that is good. Keep up with the FC!
JohnN said:You're almost there. Just keep doing what you are doing. Isn't it a great feeling having control of your pool?
Catherineb said:techguy said:Your CC is coming down and that is good. Keep up with the FC!
Thanks Techguy.
Test just now 2.45pm
FC 7
CC 1.5 just added 54oz of bleach.
So to understand this correctly. The FC will keep losing through the day in order for the CC to come down. CC now 1.5. I am excited. Keep shock level to 10ppm through day and do the Overnight test. Keep on going!!
Richard320 said:This is taking far too long. Don't wait until tonight to repeat the process - check it again in two hours and top off the bleach. Don't let up - algae is a formidable foe. Once it's knocked down, kick it! Again and again and again until it's dead.
Brushpup said:Catherineb said:techguy said:Your CC is coming down and that is good. Keep up with the FC!
Thanks Techguy.
FC 7
Actually it isn't as she just started with a nearly complete new fill. She drained mainly because of Ammonia issues and high CYA, not so much because of Algae. She is already down 3.0 on CC from earlier today and that is significant. Making good progress I would say.
Keep the FC up Cathy and you will be home free in no time.
