UPDATE:
Last week I added an additional 8oz of Cyanuric Acid in a sock.
Filter Pump running for 3-4 hours before test, SWG on (with pump also on) for an additional 3 hours before this.
Water Temp: 72
CYA: 55
pH: 7.5
FC: 14.5ppm (using 10ml, 29 drops)
CC: 0ppm
TA: 100ppm (10 drops)
It appears my CYA is unchanged from my 6/11/2014 test even though I added an additional 8oz of Cyanuric Acid last week (Pool Math said 9 more oz). It was all dissolved in the sock, I even squeezed it every other day to help it along. Not sure what to make of that.
My pH is down a bit but good at 7.5.
More concerning is my FC, now at 14.5ppm. I've been running the SWG 3 hours a day (1 hour less than the manufacturer's recommends for this pool).
Question 1: Should we stay out of the pool with these FC Levels? The pool only has had one day use by me (very limited) this year.
Question 2: Should I not run the SWG at all over the next few days? I can just run the filter pump without enabling the SWG.
My TA has increased a bit, now at 100ppm. Question 3: Is this still ok?
I also checked with the hth 6-way test and everything lined up with Taylor's results, including the high FC. The htc was at the last (dark purple) color for FC, showing 10+.
