Moved into a house three years ago, and have had pool service since then, but I figured I would look into doing it myself since I WFH now. I know the chemicals are a bit out of whack due to puck usage, so it'll take some work, but I have a few questions.
Current readings: (I have a TF-100 kit, as well as the WaterGuru monitor. The WG monitor is really just something I'm using to compare against the TF100 results)
TC: >5 (TF100)
FC: 7.5 (TF100), 6.5 (WaterGuru) - I use CalHypo (non-stabilized) pucks in a floater as of about a week ago.
PH: 7.5 (TF100), 7.6 (WaterGuru) - I added muriatic acid about an hour ago. It was at an 8.3 on the WaterGuru.
CYA: ~100 (TF100), 117 (WaterGuru)
TA: 100, (TF100), 92 (WaterGuru)
- My CYA has been all over the place since we moved in, but always high. It's been as high as 140 according to TF kit, so I honestly don't know what's accurate. We don't get enough rain (San Antonio) to dilute it, so any water changes have just been filling it when it evaporates.
- My PH changes a LOT on the daily. We have a connected spa/pool so there's some spillover, which I've read can spike PH, but I'm adding acid seemingly every other day because it's getting high (according to WaterGuru). We also have a fountain that is turned on occasionally (maybe 2x week) and will cause surface disruption when it's on. Are these the culprit for PH variance?
- I'm getting some algae growth. Not sure which high/low number could be causing this.
Questions:
1. Can the above readings be considered accurate with the high CYA number? That's the first thing to be handled, right?
2. We want to re-plaster the pool and was thinking next year. Cost aside, should I just accelerate that timeline, and do it now while we won't be swimming, and just start from scratch on water chemistry?
3. My MAIN goal is to have a very low maintenance pool. Cost aside, would transitioning to a SWG make this much more low maintenance moving forward?
Thanks all! From my browsing, this is the most helpful community I've ever seen on the web. Let me know if there's any more information I need to provide.
TC: >5 (TF100)
Questions:
