TeenaTeens....I am having the same issue you are. I started the TFP method about 3 weeks ago after doing a FULL drain/refill. I seemed to be fighting rising Ph and thus have to keep adding MA. I was also aiming for a lower Ph (7.2-7.4) which caused me to constantly add MA and more of it.The good thing was...I think adding all that MA helped keep my TA from rising. However, in the last 7-10 days or so, I started aiming for a higher Ph (7.6-7.8) thinking that would help from needing to add so much MA by finding a stable Ph level.
My problem now is....my TA was steady for the first 2 weeks when I was aiming for a lower Ph (tested TA 7 days ago= 70). now tonight it's 80. So, I think the fact that I am adding less MA is now causing TA to rise.
Interesting side note that I discovered over the past two days though. The pool size that I have been using for all my calculations has been wrong. So, when I was adding Chlorine and Muratic Acid...it was not getting the pool to my anticipated levels. For example, when I THOUGHT I was adding enough MA to drop my Ph to 7.4, it was only dropping it to 7.6. So when I was testing the following day...and my Ph was at 7.6, I was thinking it had risen by .2....in actuality it hadn't risen at all. So the Ph rising issue I *thought* I was having....I might not be as bad ad I was thinking. I was using 18,000 galloon pool size (verbally told my my PB)...and after looking at my PB paperwork..it is close to 19,000.
Knowing all this..I think I am going to aim for a "lower" Ph again (7.2-7.6). It is my understanding that it does require a bit more MA to drop Ph from 7.6 to 7.2 (verses dropping it from 7.8 to 7.4) so I think that should help keep the TA from rising too fast.
Edited to Add :I read on another thread that if you need a drop in your TA...let your Ph rise to 8.0, then add enough MA to lower it to 7.0-7.2.That will drop it a "good" amount. Then from there, you can in theory maintain that lower TA level...by aiming for a lower Ph on a daily basis?
I am still new to all of this...so I defer to the experts...
