- Jun 29, 2022
- 23
- Fiberglass
- Hayward Aqua Rite Pro (T-15)
Hey folks!
Thanks in advance for all the awesome support - this community is awesome.
First, here's a link to my pool's info. (My real-life nickname is Grubby, thus the silly pool name)
Tl;dr:
TA *increased* after adding MA and SLAM levels of chlorine. Total chlorine seems to have gone up over-night after starting the SLAM process. Is something weird going on? Do I not understand TA and/or chlorine counts? PEBKAC error? Also, when reading the label on Bleach, should I read the Sodium Hypochlorite active ingredient percentage (7.5% in this case), or the "Yields 7.1% available chlorine" note at the bottom of the label?
Narrative:
My new TF-Pro *Salt (with magnetic stirrer, which is pure magic) showed up (finally!) and I took some readings yesterday. My pool is nice and clear (or so I thought...), and it was late afternoon here in Las Vegas in full sunlight, but I couldn't resist taking some measurements. I was so excited!
FC - 0
CC - 0
pH - 7.5
TA - 120
CH - 250
CYA - 60
NaCl - 400 (my SWCG isn't active, just wanted to know what was in the water right now as a baseline for when I move to get it up and running)
Looks like after a busy weekend in the pool, my usual Tri-chlor pucks (pool-guy recommended) just didn't keep up. So....a SLAMming we shall go!
I filled my pool to the correct level (lost about 3" over the weekend), and took my next set of readings. I'm new to this, so wasn't sure by how much things would change with topping off the pool and measuring after sunset. Results:
FC - 0
CC - 0
pH - 7.5
TA - 120
CH - 275
CYA - 60
So...first lesson learned, even 3" in a 15kgal pool doesn't really move things very much. I assume that the Calcium Hardness change is actually a PEBKAC error.
Armed with my test results, I started the SLAM process by turning the pump all the way up and dropping my pH to 7.2 by adding 32oz of 29% Muriatic Acid that the previous owner left behind. Jeebus. That stuff is no joke. I didn't research much about *safe* ways to add it to the pool. So, I started by pouring from about shoulder-height from the measurement bucket. Thank Thor I didn't get splashed on. I was down-wind, and so got hit with a big whiff of gas. I immediately stopped what I was doing, got fresh air, and then pulled up TFP and researched how to *safely* add MA. My experience was much better after that.
After letting the pool agitate for about 15 minutes, I took a reading to confirm my pH had shifted to 7.2 (which it did, exactly. Thank you Pool Math app!) Next step was to bring the pool up to SLAM chlorine levels. First things first, I learned my lesson with the MA - and so I pulled up TFP and looked up how to safely add liquid chlorine (bleach) to the pool: pour slowly in front of a return in the deep end, about 2mins pour time per gallon. Got it! So, again, many thanks to Pool Math, (cross-referenced with the CYA/Chlorine chart here to extra assuredness) I added 626oz of Bleach, which was supposed to bring my FC count up to 24ppm, but here's what I got (full battery of measurements just to practice again with the kit, especially the CYA process, which feels weird still):
FC - 26
CC - 0.5
TA - 160
CH - 400
CYA - 60
Here's where my first questions come up. I added MA to drop my pH, which should have also dropped my TA, as I understand it. Do high chlorine levels render TA measurements in-accurate (like pH readings)? Or have I screwed up my measurements? Also, I read Sodium Hypochlorite of 7.5% on the active ingredients label, but Clorox added a note: "Yields 7.1% available chlorine". Is it correct to use the Sodium Hypochlorite or available chlorine percentages? If so, would that explain why my FC was high? (I used 7.1% instead of 7.5% in Pool Math)
Anyway, after adding the chlorine, and while waiting for it to mix in for 15 mins or so, I grabbed the brush and started scrubbing the ever-loving-daylights out of the side of the pool (I had noticed a slight green hue in the deeper end of the pool on the lower part of the walls earlier in the day). In fact, I ended up brushing the whole pool. Suction cleaner was also going to work this whole time, so I logged some vacuum and brushing maintenance in the pool math app as well.
Fast forward to about 20 mins before sunrise this morning, and I took just a Chlorine reading:
FC - 26
CC - 1.5
I expected FC to drop commensurate to the CC increase as I likely brushed some algae into the water that the Chlorine was interacting with. Instead, my FC seems to have held steady while the CC increased. Where did the extra chlorine come from?
Thanks again for all your help!
Tl;dr:
Narrative:
FC - 0
CC - 0
pH - 7.5
TA - 120
CH - 250
CYA - 60
FC - 0
CC - 0
pH - 7.5
TA - 120
CH - 275
CYA - 60
FC - 26
CC - 0.5
TA - 160
CH - 400
CYA - 60
FC - 26
CC - 1.5
