Bought this house 2 years ago, old owner used tabs, shock, and Leslie's "perfect weekly" to keep the pool maintained. It is a 15k gallon pebble tec pool with a variable speed pump and sand filter. The pool has been getting green lately and I would like to switch to the TFP method and do a SLAM, but after reading about it, I learned the importance of doing your own measurements and wow do I have some issues. I would like to use liquid chlorine as sanitizer.
I bought a TF-Pro test kit to perform all these measurements.
FC 0.5 ppm
CC 0.5 ppm
TC 1 ppm
CH 1,075 ppm
TA 160
CYA 200+
I did the 1:1 distilled water : pool water method to try and get a better reading of the CYA, it is probably ~250.
Should I do an 80% drain to get the CYA under control? I live in Mesa, AZ (suburb of PHX) so I think I will need CYA to be on the higher end of things. I get my water from Apache Junction so a full refill would cost me ~$60 but I am not sure if the sun would damage the pebble tec while I do a drain and re-fill.
Thanks!
Mike
FC 0.5 ppm
CC 0.5 ppm
TC 1 ppm
CH 1,075 ppm
TA 160
CYA 200+
Thanks!
Mike
