after following the TFP method for years with few issues, I have decided to make the switch given chlorine pricing and I am finding myself away from the pool for longer periods. I have yet to open the pool for the season but plan on doing so this week. Water temp is hitting 62. I have a number of question:
1 I am thinking the circapool rj-30+ and upgrading to the 45. assume that makes sense. Since our system is not automated and is an older system I do not need to match anything. Do I need to go bigger given I run my pump 24/7?
2. Wiring: our pool backs to woods and is a flooded system with the pool pad sitting below the pool grade by several feet. As such, I run the variable pump 24/7 for the entire pool season. Not on full but strong enough to keep the surface clean. I do not have a timer on the VSP. Not sure whether I need a timer for the SWG or not in this case. I do have a timer running our side cleaner that runs generally 12am to 5am. i hate to print this but the booster pump is original 13 years old and I bought a robot cleaner when I thought it was going out 2 years ago. Still running strong but I could wire into that timer? Thoughts? What if 5 hours is not enough to generate salt needs. The pool is in full sun most of the day. Not sure I will have enough pole space for another timer and the SWG controller. power is 220.
3 location is tight coming out of the heater. I have a 2 way valve splitting the return to a water feature. the main run then splits for the returns and a supply to a slide. Any problem running this to the slide too Or will the chlorinated flow cause streaking etc? The water features have brass fittings. they are 4 little fountains into the pool. Don’t use those too much since not automated. I am thinking a vertical install would be best. Interested on your thoughts where to install without redoing the other plumbing but if need to move those your suggestions. See pics (note pool is still winterized)
4 do I need a check valve on the line from the heater?
5. Any other parts I will need to order when ordering the SWG?
6 I have some minor missing pebbletec that needs to be repaired so there is some exposed gunite From prior posts I have a broken line to one of the four water features that has bulged behind the coping tile my pebbletec is also original to the pool. Any c8ncerns switching to salt with these outstaying repair todos?
thanks as usual for everyone help.
