So I'm opening a pool that we had remodeled last year, so it was filled with fresh water last fall. My fill water has pretty high TA apparently, but the PH is in a good spot at 7.5 I know the general idea is to not worry about TA unless PH is always high or Scaling Index is high. Since I'm adding a SWCG and a lot of salt in a couple days should I get TA down now so I'm not fighting PH with the new salt water system, or install and just see what it does.
My plan is to shock the pool and get water balanced and then turn on the SWG.
Readings
FC: 0 CC: 0
PH: 7.5
CYA - 20 (added stabilizer last night to get it up, haven't retested yet)
TA: 190
Salt: < 1000
Cal: 300
Water temp: 59
Readings
FC: 0 CC: 0
PH: 7.5
TA: 190
Salt: < 1000
Cal: 300
Water temp: 59
