I'm nearing the final bend on my journey to a SWCG pool and have a balanced pool being maintained daily with liquid chlorine.
With CYA 45 I'm bringing FC to around 5 and topping it back up to 5 when it gets down to 3 or so. When I switch to SWG I'm planning to run CYA 70 and FC with a hard minimum of 3 (SWG will be a PL45+ 45g/gr, double capacity).
My pool gets little use from people other than myself and CC has been 0.0 at at most 0.1.
The water has been great, no "chlorine smell". Woohoo!
Not particularly "silky feeling", but to be honest if I don't shower afterwards I do find my skin feeling slightly dry and slightly dry eyes. You might say "Well, you should shower afterwards". If that's a part of chlorinated life™ I guess so be it. But I think part of the TFP pitch is that there is going to be less chlorine in the water than drinking water and you wouldn't shower after a shower, right? Maybe once I switch to SWG and can wind the FC down a bit this will get better. And install an outdoor shower. I'm pragmatic.
Pool Math tells me I will need 263kg of salt to get from 500 to 3000, so I'm about to order 11 bags of no-additive pool salt (in particular no yellow prussiate of soda!). Before I push the button on that purchase.... should I consider mag salt instead (ie: the usual Magnapool mix - regular salt, mag salt, potassium)?
Other threads asking the question "Should I use mag salt" have had the question returned "What are you hoping to achieve"? It would be:
The downsides seem to be you have to do a bit more fiddling on your CH test or need an alternative CH test, and more expensive bags of salt but for a super nice feel that would seem a worthwhile value proposition to me.
I am leaning towards sticking to the tried and true TFP path of regular salt especially after all my dramas, but happy to spend a little more for this magical "silky" and "soft" experience I'm hearing about (and apparently going to experience myself with their "bath-sized sample" sachet....).
- "Nicer" feeling water (the terms "silkier" and "softer" get thrown around, and MagnaPool is sending me a "bath-sized sample" so I guess I will be able to make a subjective assessment of this)
- Better feeling skin out of the water if you don't shower (I don't know if that's a thing)
- Less salty taste than equivalent 3000ppm salt water (I don't know if that's a thing, and I have also heard mag-salt water tastes bitter which would be arguably worse than "almost-salty" tasting 3000ppm water)
