We have two water meters: a 1" domestic and a 2" for the irrigation and, previously, the pool autofill. The pool and house were built in the 19500s when the pool supply line could be connected to the irrigation supply line.
When the pool was remodeled, the building code required the pool to be connected to the domestic line instead. The contractor did this by jury-rigging a connection to a hose bib with a right angle cut-off and a y-splitter to enable both a hose connection and the other with a backflow valve connected underground to the autofill.
I have no idea what happened to the previous connection to the 2" line but am wondering if something is still connected because I discovered that when the sprinkler system runs on the 2" line, the meter on the 1" line MOVES slowly indicating water is flowing through it as well (even though nothing is running in the house), most notably when one zone of the irrigation near the pool equipment is running. Could the 2" line be sucking in water from the 1" line?
Any guidance in figuring out this mystery would be greatly appreciated!
