mp,
Where did you get the 2300 number??? Pentair cells operate between 2800 and 4500... You want to try to be in the middle of this range..
I thought I saw 2,300 as a recommended number.
The midpoint of your numbers is 3,650.
That would be 672 Lbs of salt, right?
Where do I get a over 1/3 of a ton of salt?
I would think you would want to add some chlorine throughout the winter. Would not take much. I assume you do not winterize, such as drain and blow out the lines? If you do, then that changes things. I run our system about an hour each day during the winter. We never have freeze issues though the pump turns on at 35F for protection.
You should not have to SLAM in the spring if you have no issues in the fall. You would simply raise your FC to your target level based on CYA (which you would increase to 70 or so if using a SWCG) and start your SWCG.
Take care.
I do have to winterize the pool. Draining and blowing out the lines is a yearly event.
Even with insulated mechanical building, the temps do drop to well below freezing over the winter.
