hello,
So are you saying I should run my swg @ 100% for a day, check my chemistry and the next day and then decide how many hours to run @ 60% from 6am until noon- 1pm 100% then back to 80% after 2-3 pm? This chemistry thing is so confusing. I am not a chemist and would prefer not to be.
I am just trying to use the Water Balance for SWGs process to keep my levels correct. I see the chemistry I should shot for but i just need the sequence in which to add the chemicals. It seems to me first get FC to 4 -6, second, CYA to 70. adding Clorox is the only way I believe I can get FC to 4 -6 as running the SWG @ 100% for 12 hours a day may cause early replacement.
Bill
Updated:
Okay, thank you. I am not sure what to do with this pool it receives sun now 12 hours a day. I just got the chemistry where I want it but the pH seems to rise a little everyday.
Here is yesterdays chem:
FC 3
TC 3
CYA 42
PH 7.6
TA 80
CH not tested i guess this is Calcium Hardness which i do not test as liner is vinyl.
I haven't tested yet today as I am looking for an answer on what sequence to I initiate the Water Balance for SWGs process. I guess I'll test the chemistry make the needed changes and wait for a response
Bill
Bill
Updated:
FC 3
TC 3
CYA 42
PH 7.6
TA 80
Bill
