- Jun 15, 2020
- 34
- Vinyl
- Liquid Chlorine
- CircuPool RJ-60 Plus
Hi,
Looking for some feedback/guidance on the plumbing I did. It's not glued yet so I can alter it if necessary.
12 inches from supply side valve to pump
Pump -> check valve -> filter -> to heater/heater bypass** -> flow meter -> swg
**If I bypass heater then I have a check valve to prevent it from going into the heater.
Aslo, the wiring is throwing me as I'm trying to install a new wifi timer.
Picture of previous timer: pump & heater. Pump & heater going into #2 and line into #1.
Breaker has 30 amp double pole.
Appears I'm at 120v since I don't have a 2nd hot (will verify via multimeter this week).
As such, I'm looking at either buying a 2nd timer and hooking the heater up to that. First one will have pump and swg. Pic of diagram I would use (once 115v confirmed) - control two 120v. Thank for the guidance!
