- Sep 15, 2014
- 17
- Vinyl
- Pureline Crystal Pure 60,000
I have the Pureline 60,000 gallon SWG for my 28,000 gallon vinyl liner pool. I purchased it from Inyo Pools and installed it in 2019 and love the ease. Last summer, it stopped generating and the lights were going crazy. Inyo said I needed to replace the control board. It was an easy switch and it worked fine again...Except.. when the pump shuts off (on a timer), the SWG stops generating as it should, and the check cell and check salt lights come on and stay on. But when the pump starts up again, the SWG doesn't turn back on and those lights stay lit. Pic attached. I have to manually turn off the SWG switch and turn it back on and then everything is working again. A real pain. My salt is 3400, my cell is clean, chlorine is 6.5, so I know it is generating. Inyo told me it "might" be the flow switch. It wasn't a problem before I switched out the bad control board. Any ideas?
