I've owned the resilience system for many years and have been very happy with it. I've had to replace the cell a few times when the blades wore out. This summer chlorine production dropped dramatically, the middle plate seemed worn and so I bought a new A5 cell form Solaxx. Even with the new cell, it is generating exremely little chlorine - 0.5 after 12 hours at 100% - this would normally have me off the charts!
I have cheked the chemicals and I have enough salt - 3800ppm. TA was a little low at 50 but everything else looking good.
I believe the control board should be ok - the lights move up and down to 100% when I turn the control know. There are no error lights on.
The new cell looked a bit different to previous cells. The plates seemed to have a brown coating vs the silver/gray I'm used to seeing and a couple of notches cut in the end.
So, I called Solaxx. They are telling me it's due to chemical imbalance - probably total dissolved solids or nitrates. I had those measured and get 45-50 TDS (inc salt) and 30ppm for nitrates. However, those have likely been moving slowly over time and it seems unlikely to me that these are causing the near zero chlorine production.
Anyone have any thoughts, or guidance for me? Thx in advance!
