Hi there,
I recently purchased a Hayward Aqua Rite SWG System and have a questions regarding the install. I have about a 5 foot run of straight pipe after the pool heater in which to install the system and will also be adding in a check value. In the manual, it says that the flow switch can be installed on either side of the cell generator. My question is, can I install the check valve in between the cell and switch? Reasoning being to protect the flow switch from high levels of chlorine when the pump is turned off, same as the heater. Any issues with this setup?
