The manual states to install the controller 10' away from the edge of the pool. Why? I don't plan on installing up against the pool but my pump/filter system is only about 3' from the pool and would like to have the controller in that area.
I've read to install the cell at a level higher than the pump but as I'm installing with an AGP, should I insure the cell is higher than the pump but lower than the jet so the cell is always water full regardless of whether the pump is on or not?
One last question for this topic...I have a two speed pump and I do not have a timer. Will it be okay to run the pump on low, set the cell to the correct % and only run the pump full speed when I'm vacuuming?
Thanks!
Thanks!
