Hi all,
Have what seems to be a strange issue. 3rd startup year with salt pool and have the ic60 intellichlor. This year everything appeared normal, balanced water, powered up ic60, lights on and looks like it’s running normally. First thing I noticed it that the system wasn’t using any acid. But then the chlorine levels still weren’t coming up and we started getting some algae I knew there was definitely an issue. Since the ic60 lights were functioning normally, I was thinking the chlorinator had failed early and needed to be replaced. Now I received a new ic60 and it’s behaving the same way. Powers up, lights all greeen, indicating it’s chlorinating. Been on for 4 days and chlorine is way down and hasn’t called for any acid.
Does anyone have experience with the power supply failing such that all the lights would still indicate that everything is ok but the cell not produce anything. I just tested the DC voltage and it was 27 without the ic60 connected.
Any help appreciated. Thanks!
