- Feb 6, 2015
- 6,125
- Plaster
- CircuPool RJ-45 Plus
I asked for a list of equipment, etc so one of our Hayward experts could chime in.I listed the pool equipment as you suggested. Would you mind taking a look? It's in one of my other comments in this thread. Thank you!
The SWG can be installed - BUT no salt is added and the SWG isn't started up until at least 30 days after pool startup. Your builder is requiring 45 days - which is fine as well.Does the above sound right -- delaying the install of the salt system?
Are you doing a separate coping and decking or a cantilevered deck?He is also suggesting we have our concrete pool coping done by the people who are doing our concrete walkways "so they'll match" but then goes on to say - "Just be advised that concrete coping and salt pools aren’t the best combination"
Ask him why "... concrete coping and salt pools aren't the best combination"
He doesn't know that every chlorine pool is a salt pool. See my comment below.....
Does he have a pool? Ask him to measure the salt content of his pool with a drop based salt test kit (K-1766) and report back to you with the result.
Well, since he basically refuses to do SWG, I guess he's out.Considering an Owner Build ---
I guess he doesn't know that EVERY chlorine pool is a salt pool. Chlorine, muriatic acid, and pool users will add salt to the pool water. After a few years, the salt will build up and the concentration will be close to or above that recommended for a pool with a SWG.
