After reading through the Bromine and You sticky, I was wondering about the utility of using a saltwater chlorine generator with bromine. Since bromine requires regular oxidization to maintain sanitizer levels, and chlorine provides that, would using bromine with a SWCG result in a system that did not have to run as frequently to maintain the sanitizer, working much like an ozone generator, and replacing the bromine floatie? Bromine then being more stable at high temperatures wouldn't require the chlorine generator to run as much as it would if you were relying on the chlorine alone to provide sanitation? Am I over-complicating this? I mean, fundamentally, bromine is an enhancement of chlorine sanitation that's chosen because it is more stable and doesn't get consumed as readily as chlorine on its own, right? It's also more effective at higher pH, making it safer, especially for smaller vessels which would experience larger pH swings. I have a Controlmatic Chlormaker system, and it's pretty nice for minimizing necessary maintenance, but I've been having some corrosion issues with the heater, and I'm interested in developing a method that reduces that as much as possible. Hence, my inquiry regarding bromine. Running the salt cell less seems ideal, both for maximizing cell life, and for reducing potential stray currents in the water driving corrosion. This seems feasible to me, anyone have any thoughts? The obvious question to me would be whether this has any advantage over just using a bromine floatie? Doing that doesn't require adding a pile of salt to the water.
