SUPER 11 PUMPS 1.5 hp TO Tristar 2.7 hp
rfrego
7
Adkins, TEXAS
I bought a house that has two Super 11 pumps. One of those is a variable pump. They are both 1.5hp. I assume one is supposed tp be used for the pool features and the other for regular filtering. So should I just shut off the VS Pool pump and only use that one when running features, or leave them both on. Just seems like a waste of money having 2 pumps. Would it be better to just get rid of super 11 pumps and but a Hayward Tristar 2.7 HP VS pump that should be able to handle filtering and the features? I think that pump cost about $1900, an idea how much install would be? Thank you!
What “pool features” does the second pump run?
Running a VS pump at low speed costs $1-$2 per day. I like to continuously filter and circulate the pool water and I use a SWG and need it to generate chlorine.
How do you chlorinate your pool?
Hi, we have a huge waterfall and 2 fountain jets on each side of the pool. We use liquid chlorine mostly ( when it’s available” but also have a Pentair R171016 Rainbow 300 Automatic Chlorinator
How much flow in GPM does your large waterfall need?
What filter do you have? None is listed in your signature.
Does your water features pump run through a filter?
Do you have a heater?
Post pics of your equipment pad.
Neither of those pumps is variable-speed. Two-speed, perhaps. Do you run both simultaneously for the water features?
