Thanks all! Funny we are all on the same page - I was thinking today that I don't really need the waterfall to work electronically - I'm going to have to go over there anyway so how much more work Is it to twist a valve in addion to hitting the aux1 button? I actually never thought of automating the waterfall until the solar guy suggested it either
Pool Clown, can you figure out how to get valve A to work when you enable the heat pump setting under the solar mode? It definitely doesn't work in single body mode - I'm just wondering if in pool spa mode this will allow me to control the valves separately? I'm going to try myself tomorrow. I'll do as Jason suggested and only wire the suction valve using spa mode to run the cleaner and pool mode to run filtration and solar.
Jason I totally agree - if the manual was more clear about how and what the controller can do this wouldn't have been so hard or taken so long. The manual doesn't even explain how the feature settings work and a bunch of other options in the controller. The first guy I talked to at tech support kept telling me that solar takes over aux 1. One of the few things that is clear in the manual is that solar uses aux 3.
Thanks to this group I hope to get this working once and for all tomorrow!
