Hello,
I'm trying to track down a possible suction side leak. Any advice?
Attached picture shows the pump inlet pipe which comes from 3 valves (shallow skimmer, main drain, and deep skimmer).
Symptoms:
Thanks for any help.
Symptoms:
- When the pump is shut off, the water level in the pump basket starts going down slowly, probably takes about 30 minutes to empty.
- The pump has to re-prime every time it starts back up (takes ~10 seconds).
- There appears to be large bubbles that come from the pump inlet pipe as the water level slowly decreases when the pump is off. These bubbles are infrequent, like every 1-3 minutes a big bubble comes through the inlet pipe into the pump basket.
- If I hold my hand on the inlet pipes, I can feel the vibration of the bubbles/gurgling when the pump is off.
- The bubbles from the inlet pipe still appear and the water level in the pump basket housing still lowers even if I close all 3 valves. So this tells me either the valves don't work or the water is being sucked towards the filter/pool returns?
- I can hear gurgling sounds some times from the sand filter when the pump is off.
- The water level in the pump basket housing does go below the inlet pipe and I can still hear gurgling despite the water level being below the inlet pipe.
- The sand filter pressure gauge goes immediately to 0 when the pump turns off and sounds like water drains from the filter area.
- Over the past couple days I have been having to add water to the pool because the water levels gets to the bottom of the skimmer.
- When the pump is running, there are bubbles swishing around the top of the pump basket housing. The bubbles never completely go away (this has always been the case since we bought the house ~7 years ago really).
- The pump and water circulation seem fine. I could run it 24/7 without issues.
- There used to be bubbles coming from the pool returns, but I lubricated and tightened the pump basket lid o-ring and I no longer notice bubbles from the returns.
- There are no visible water leaks from any of the above ground plumbing.
- I don't notice any water drips from the pump area when the pump shuts off.
- There are no wet spots anywhere and no wet/damp ground.
