- May 3, 2007
- 16,964
- Plaster
- Hayward Aqua Rite (T-15)
Re: STS1072R vs STS1072RV1; capacitor hump; "Conservationist
A.O. Smith, now called Regal Beloit, now has a two speed motor with a run capacitor for both the high and low speeds. They call it the E-Plus Centurion.
You have to be careful how you read torque curves. The x-axis is the speed of the motor but with the main full speed windings (note the chart is labeled high speed). In other words, it is reflective of slip. When a motor first starts the slip is 100% so RPM is 0. As the motor spins up, slip reduces until the motor settles at around 4% slip for full load. The chart can also be used for overloaded situtations where slip increases and power usage increases. So full load is on the right most side of the curve (3450 RPM) and overload moves the operating point to the left which slows down the motor, increases torque and increases power.what i find strange from the spec pic is that watts are dropping as speed increases. i'm probably reading it wrong.
