The pump motor runs and the rollers are squeezing the tube, but no acid is pumped.
I thought I just needed a replacement pump tube--that's been the solution in the past.
I put the same pump tube on the adjacent stenner pump (along with attached tubing) that's used to dose chlorine and it works--acid is dosed as expected.
Only thing I can think of is that the rollers have worn over time so they are smaller diameter and not longer squeeze the pump tube enough? Has anyone seen this?
(Hate to buy a new pump head assembly if that's not really the issue).
Thanks!
Thanks!
