Could any reagents have gotten too hot, aged? And the result of that is funky numbers? Just thinking out loud and by fingertip as I read this thread?
I see you started this pool in 2015, I would think that the reagents are fine, but you do live in California and I know it can get hot there.
Now I know this season, after 3 seasons my sand was fouled. Which many will think it wasn't but I had horrible tree* droppings inside of that turned to sludge.
If you have tried everything else but have not deep cleaned, I think at this point I would, if for nothing else just to check that duty off the list and for sanity.
8400 gallons in California, you could be doing a bit of baking in that tank. Be careful with the hose so you do not disturb your laterals, but get a hose in there and flush everything out.
Are you sure of your bleach strength? Did you check the dates on the bottles and do you store your bottles in a cool shady spot?
The wand that you attached to sweep, I know mine will hold a bit of water in it so I make sure to drain it over top of the water and if I set it down one end is always elevated so anything that didn't slide out does while it is at rest.
Can't really think of anything else right now, just finished a marathon yard session that started at 7 this morning and I am too old for that anymore
Just trying to offer up something that helps. Stay the course you are close, check dates on those bleach bottles and deep clean the filter. And try not to lose your mind in the process
