- Jul 4, 2012
- 749
- Vinyl
- CircuPool RJ-60 Plus
I could definitely attempt this. My wife is pretty anxious about leaving it open with all of our kids, so I'll have to get her buy-in. Luckily I work from home, so maybe I can convince her that I will babysit the pool all day. Honestly I'm not terribly concerned about the persistent CC at this point. Much more concerned about how to avoid having to slam once every other week. I don't disagree with you that I'm missing something, but I have no clue what or where it may be...One thing I'd try is leaving cover off for the full day. You'll lose more to UV so will need to replenish more often but keeping the cover closed is what is likely leading to the persistent CC you are seeing.
Yes !Can algae be hiding in the cover vault?
A drain is goodI'm not at home now, but here's a photo from my security camera. It's a Pool Safe cover (Automatic Safety Pool Covers | Poolsafe). There is coping sitting on top of brackets over top of the vault. I *believe* that they're just held in place by gravity and friction, I can try to removing some of them when I'm back home. Honestly though the coping pieces probably weigh 50-80 lbs each and it's going to be a real pain if that needs to be done regularly...
There is a drain in the vault I know that for sure, but I'm also certain that it's damp most of the time due to splashing and lack of sunlight in there.View attachment 516599
Perhaps you can just carefully remove a piece here & there to get access to spray it out & see what’s going on in there. I think with the cover closed you should be able to see in there & spray/blow it out without making a mess in the poolHere's a couple more photos of the vault with 1 piece of coping removed when they were working on it I could find in the security footage.
View attachment 516607View attachment 516608
Haha, it sounds so simple! Just am going to have to convince my wife that this is the path forward, she hates the idea of the pool open while we're sleeping.Leave the cover open, clean your test vials and spinner bar with bleach, then alcohol. Then do a proper oclt. it will take the cover out of the equation.
Is it your only safety device? Edit- I see you have a fence. Do you have alarms?Haha, it sounds so simple! Just am going to have to convince my wife that this is the path forward, she hates the idea of the pool open while we're sleeping.
