I purchased an SR Smith ART-1004 Deck Mounted Stair Rail along with two AS-100B Pool 4" Bronze Anchor Sockets. In Late September 2022 these were installed by the pool installation company while pouring the concrete patio for the smaller (6000 Gallon) in-ground fiberglass pool. Since then, periodically, the handrail gets so loose it can be just lifted out. On four occasions, the retaining bolts have had to be tightened. I have been careful to not over tighten the retaining bolts so as to not damage the handrail, but I tightened them quite firm. When I tighten the handrails there is no movement at all, then they loosen up again. When using the stairs/rail there is not undue strain on the handrail from pulling as I am the only adult using the pool, and I hold it for balance only. I do not pull myself up via the railing.
No glue/lock agent has ever been applied to the anchor socket bolts.
I do not currently have a torque wrench, nor do I have the torque specification for the anchors
What might be the issue with the anchor sockets.
What might be done to firmly anchor the rail to the socket so it does not loosen up?
Thank you for your help.
