Hi - i opened my pool this year to a weird discoloration in my deep end. It is more a yellow/green ahade (attaching picture). Some info on a situation that happened this past offseason to help with my question. I routinely pump my pool down with a sump pump as well as ground water around my pool for hydrostatic pressure. This past year i got distracted and took it down too far. In a panic i dropped the sump in my hydrostatic pipe and pumped water from around my pool to fill it back above ground water level (fiberglass pool). In any event, i wonder if that could be some of what im seeing although that still doesn't make a lot os sense to me. For now, i have tried ascorbic acid and rubbing a chlorine tablet on it - neither seemed to make a dent. I brush daily to hopefully wear it away as the pool balance works its magic but wanted to see if anyone had thoughts. Some of what i read on organic stains said it takes time (which is why I target brush it daily) but if there are other trick I would love to hear them. Once the water is warm enough i can get in to inspect - for know it is all from above which is a bit difficult.
Thanks
Mike
Thanks
Mike
