- May 25, 2020
- 83
- Plaster
- Pentair Intellichlor IC-40
Last year I had high CH levels and needed to drain my pool. I used the spigot, connected a hose, turned the pump off, and opened the spigot and drained no problem. My CH was high again this year and I got help here to identify and finally solve the issue (my water softener wasn’t large enough because it was put in before pool build).
I now have the CH pretty well balanced but it’s still high from before the WS was replaced so I need to drain roughly 70% of my water according to the app to get it to a lower level and refill with soft water. I went to repeat the process I did this year and the pool will not drain through the spigot unless the pump is running. Did I forget something and miss a step? If I disconnect the hose and open the spigot, sure enough no water spewing out. If the pump is running, water spews out. I know that I’m not supposed to run the pump when draining and I can’t figure out what I did differently last year to make this work.
Please help and let me know what I’m missing :/
