Hello,
I have a fairly new (3 years, 4 months) Pentair System. 3 HP Intelliflo VSP with Intellichlor Salt Cell. In addition, Master Temp 250 Heater.
I have no flow issues with pool running and also when running pool and spa bubbler.
If I switch to spa overflow, the T-Jet actuator turns as designed 180 degrees. The red flow light on the Intellichlor comes on and you can hear air in the pipes.
When turning on the Spa, the T-Jet and Spa Main Drain Actuators turn 180 degrees. Red flow light on Intellichlor comes on and again, can hear air in the piping. All four jets in the spa are on. The red service heater light is on the heater.
Any suggestions or thoughts would be appreciated.
If additional pictures are needed, let me know.
Thanks
Thanks
